Введение
In this guide, you will learn how to replace your HP Pavilion Sleekbook's screen.
Выберете то, что вам нужно
Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon).
Press the switch on the right-hand side of the back of the device towards the center until the gray battery icon is no longer visible. This will eject the battery.
Using a 1.0 Flathead screwdriver, remove the two stickers covering the screws that hold the screen in place.
Use a Phillips #1 screwdriver to remove the two 3.2mm screws that are now visible.
Using a plastic opening tool, pry the plastic screen protector off, sliding the tool along the seam. Press the tool in until you hear the plastic tabs clicking as they come undone.
Separate the plastic that makes up the hinges for the screen, as they are part of the same screen protector.
Use your hands or plastic tool to peel the screen protector away from the adhesive holding it in place.
Using a Phillips #1 screwdriver, remove the six 2.8mm screws holding the screen in place.
Lift the screen away from the cover until you have access to the connector cable near the bottom of the screen.
Peel away any sticker holding the connector in place and simply pull the tab out of the connector parallel with the screen.
Remove the screen from the device.
Еще один человек закончил это руководство.
