Введение
This guide will go through the steps to replace the screen if it is not displaying anything or the display is distorted.
Выберете то, что вам нужно
Slide the battery lock on the right side open.
Slide the Battery release latch on the left side.
Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
Using the spudger to lift up on the white tabs
Pull horizontally on the blue ribbon to disconnect the cables
Starting at a top corner, use the pry tool to split the case.
Slowly work around the case, pulling up gently to release the clips.
Lift up plastic over latch for the screen.
Pull the connector away from the screen to disconnect it.
