HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement
Выберете то, что вам нужно
  1. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement, Hard Drive: шаг 1, изображение 1 из 1
    • Remove the battery from the device and unplug it.
    • Keep different sized screws separated from each other during disassembly and reassembly.
  2. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: шаг 2, изображение 1 из 1
    • Using a Phillips #0 screwdriver, remove the two screws on the small back cover.
    • Remove the cover.
    • Remove the three screws that have been uncovered.
  3. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: шаг 3, изображение 1 из 1
    • Remove the two rubber screw covers by the rubber feet of the device.
    • Using a Phillips #0 screwdriver, remove the two screws that have been uncovered.
  4. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: шаг 4, изображение 1 из 1
    • Using a Phillips #0 screwdriver, remove the eight screws as directed.
    • Using a Phillips #1 screwdriver, remove the two remaining screws.
  5. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: шаг 5, изображение 1 из 2 HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: шаг 5, изображение 2 из 2
    • Using the plastic opening tool, gently pull up the keyboard starting from the bottom left corner, working your way to the bottom right corner.
    • To remove the keyboard, lift up the plastic retaining tab with the opening tool and gently pull out the ribbon wire.
  6. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: шаг 6, изображение 1 из 1
    • Remove the plastic cover of the laptop using the opening tool.
    • The plastic cover is fragile, be cautious during removal.
  7. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: шаг 7, изображение 1 из 1
    • Using the plastic opening tool, pull up the retaining tab and and pull out the ribbon wire
    • This port is fragile, take care in removing and reinserting the ribbon wire.
  8. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: шаг 8, изображение 1 из 1
    • Using a Phillips #0 screwdriver, remove the six screws on the hard drive, then remove it.
    • Be sure to properly dispose or recycle your hard drive.
Заключение
Justin Hurley
Участник с: 01/14/19
1 Репутация
1 руководство автора
Команда
IUPUI, Team S6-G6, Wilson Spring 2019 Участник IUPUI, Team S6-G6, Wilson Spring 2019
IUPUI-WILSON-S19S6G6
3 членов
Автор 1 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 10
За всё время: 350
