Введение
This guide will explain how to reach and remove your laptop's motherboard. The motherboard is hidden beneath several other components that will all need to be removed.
It is very important to keep track of everything you remove from the device, especially the screws, as losing or damaging pieces may cause even greater damage to the device. A recommended strategy is to place each component and its screws in a separate, labeled container.
Инструменты
Запчасти
Детали не указаны.
Begin by turning the laptop over so that you can see the bottom of the computer.
Slide the battery release switch to the right while simultaneously lifting up the battery.
Disconnect the lower fan connector from the motherboard.
Remove the metal plate and lower fan.
Disconnect the upper fan connector from the motherboard.
Remove the four spring loaded screws holding the heat sink assembly to the motherboard.
Slide the heat sink assembly including the upper fan out by pulling it down and left simultaneously.
Begin after removing the battery and fans.
Remove the screws from the outer frame of the laptop.
Remove screws from the battery area, noting the following:
These screws are on oversize clearing holes, but hold other components on the keyboard. It is not recommended to remove them yet.
Two screws secure the optical drive: one in the battery compartment and one in the RAM compartment.
With the screws removed, PUSH the optical drive out through the opening at the BLUE arrow. You will need to remove the drive to access two more screws at the edge of the frame in the opening of the optical drive.
Using a flathead screwdriver, remove two screws on the left-side panel of the laptop.
Open the laptop so that both the screen and keyboard are in view.
Carefully pry off the frame above the keyboard.
To begin disconnecting the monitor, remove two screws.
Make sure to keep the screen propped up to reduce the amount of strain on the screws as you take them out.
Disconnect the two wires connecting the monitor to the rest of the laptop.
Do not tug on the wires. Just like wall plugs, you need to disconnect them from the actual point of connection.
Remove the screws holding the keyboard to the chassis.
Unplug the wire just below the right screw shown and the small white connector to the left of that screw.
The far end of the keyboard bezel may still be held by two screws that can only be accessed by removing the optical drive (as mentioned in Step 9).
Disconnect the three ribbon cables attached to the motherboard.
See images 2 and 3 for a closer look.
Remove the screws from the motherboard.
There are many different sizes and types of screws here. Make sure you are keeping track of where they all belong.
Pry the frame off the laptop outwards while simultaneously lifting the motherboard out of it.
9 участников успешно повторили данное руководство.
Комментариев: 4
this guid is perfect for a new bee to disassemble a laptop.forget about grammer and bullets points.follow the images it is great
Very helpful guide, thanks a lot.
