Введение
If the hard drive on which your OS is installed fails, you will see a system error screen. If so, you will need to replace your main hard drive.
Выберете то, что вам нужно
Turn your laptop over so the bottom of your laptop is facing up and the hinge is located away from you
Lift up the released battery by rotating it up and away from you.
Pull the battery out.
Locate two 7.5 mm screws on the hard drive case plate.
Use the Phillips #0 screw driver to loosen both 7.5 mm screws.
4 участников успешно повторили данное руководство.
