Введение
Before replacing your keyboard, remove the battery. To remove the keyboard you will first remove some covers on the back of your computer, the optical drive, and the keyboard frame.
Выберете то, что вам нужно
Turn your laptop over so the bottom of your laptop is facing up and the hinge is located away from you
Lift up the released battery by rotating it up and away from you.
Pull the battery out.
Turn the laptop over so the bottom is facing up and the hinges are pointed away from you.
Use a Phillips #0 screwdriver to remove the three 2.5 mm screws that are located in the battery socket.
Remove the two 14.5 mm screws with a Phillips #0 screwdriver.
Remove the four 7.5 mm corner screws with a Phillips #0 screwdriver.
Locate and unscrew the 7.5 mm screw on the CMOS cover.
Pull up the cover with your fingers.
Remove the cover.
Use a Phillips #0 screwdriver to remove the 14.5 mm screw that is located inside the CMOS socket.
If the lock switch is operational, slide the lock switch up vertically to release the optical drive.
Remove the optical drive after it is released.
Locate the optical drive on the bottom left wall of the laptop.
Remove the optical drive control panel with a thin flat tool
Turn the laptop over and open the laptop.
Gently lift up the frame surrounding the keyboard without pulling off the keyboard.
Disconnect the 2 ribbon cables attached to the surrounding keyboard frame.
Remove the surrounding keyboard frame but not the actual keyboard.
Gently lift up the key board from the side closest to you, flipping the keyboard away from you. Do not remove the whole keyboard just yet because there is a cable that has to be
Locate the two grey tabs on the right and left sides of the ribbon cable.
Push both grey tabs up towards the back side of the laptop with your fingers or a plastic spudger.
When the two gray tabs are pulled up, you are ready to go on to the next step.
Gently pull the flat cable out of the retaining flap with your hands.
Remove the keyboard from the laptop.
2 участников успешно повторили данное руководство.
3 Комментариев
On Step 13, there is a screw connecting the frame near where your left hand is gripping the frame that was not mentioned. You have to lift the keyboard a bit to access it.
Edit to my earlier comment: On Step 13, there are two screws connecting the frame near where your left hand is gripping the frame that were not mentioned, one similar in size to the two that were removed after the optical drive in step 11 and one similar to the four removed in step 6. You have to lift the keyboard a bit to access them.
Great Guide!!
