Введение
If your laptop fails to boot up while making beeping sounds, your internal memory (RAM) is most likely corrupted. If your laptop is constantly crashing, particularly during difficult tasks such as graphics-intensive games, it is likely you do not have enough RAM for these processes.
Выберете то, что вам нужно
Turn your laptop over so the bottom of your laptop is facing up and the hinge is located away from you
Lift up the released battery by rotating it up and away from you.
Pull the battery out.
Use the Phillips #0 screw driver to unscrew the 7.5 mm screw indicated in the photo.
Locate the 2 silver release buttons inside the RAM socket, indicated in the pictures. They are on opposite sides of the socket.
Simultaneously push the two silver release buttons away from each other towards the walls of the socket to release the RAM from the socket.
2 участников успешно повторили данное руководство.
