Введение
After removing the battery you will remove the case cover on the back of your computer, then detach two wires connected to the wifi adapter/card, and finally remove the wifi adapter/card.
Выберете то, что вам нужно
Turn your laptop over so the bottom of your laptop is facing up and the hinge is located away from you
Lift up the released battery by rotating it up and away from you.
Pull the battery out.
Locate the two 7.5 mm screws on the hard drive case plate.
Use the Phillips #0 screw driver to remove both 7.5 mm screws.
Locate the two antenna cable connectors. One is white and the other is black.
Pop off the two antenna cable connectors using your fingers or a plastic spudger.
2 участников успешно повторили данное руководство.
Один комментарий
Saving $$$ doing it myself, thanks this tutorial made it easy.... Thanks....
