HP Pavilion dv5000 Keyboard Replacement
Выберете то, что вам нужно
  1. HP Pavilion dv5000 Keyboard Replacement, Battery: шаг 1, изображение 1 из 1
    • Turn off the computer, and unplug it from all external power sources.
    • Lay the computer face-down on a flat surface. Orient the computer to match the image.
    • Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
  2. HP Pavilion dv5000 Keyboard Replacement, Keyboard: шаг 2, изображение 1 из 1
    • Remove the two 11.0mm screws at the corners on either side of the battery compartment.
    • Remove the three 6.0mm screws.
    • Remove the two 5.0mm screws.
    • Remove the 6.0mm screw in the middle of the battery compartment.
  3. HP Pavilion dv5000 Keyboard Replacement: шаг 3, изображение 1 из 1
    • Turn the computer over and open the screen. This provides access to the screen hinges.
    • The keyboard switch cover is attached to the computer with a series of snaps. With a flathead screwdriver, pry up the switch cover until it pops free.
  4. HP Pavilion dv5000 Keyboard Replacement: шаг 4, изображение 1 из 1
    • Be careful not to bend the keyboard switch cover too far when removing it.
  5. HP Pavilion dv5000 Keyboard Replacement: шаг 5, изображение 1 из 1
    • Next, remove the keyboard. Push on the keyboard frame above the function keys and slide the keyboard toward the screen.
  6. HP Pavilion dv5000 Keyboard Replacement: шаг 6, изображение 1 из 2 HP Pavilion dv5000 Keyboard Replacement: шаг 6, изображение 2 из 2
    • Carefully lift the trackpad-side edge of the keyboard to reveal the LED and keyboard cable connectors.
    • Detach the cable connectors from the computer by gripping each cable connector close to the computer contact point and pulling up gently.
    When reassembling, you need to push the little tabs next to the connector up before connecting the cable.
    Dimitri Cooper - Ответить
  7. HP Pavilion dv5000 Keyboard Replacement: шаг 7, изображение 1 из 1
    • This step is for replacing the keyboard only. If you are not replacing the keyboard, skip this step.
    • Lay the keyboard face down.
    • Remove the four 3.00mm screws that attach the keyboard to the keyboard frame.
  8. HP Pavilion dv5000 Keyboard Replacement: шаг 8, изображение 1 из 1
    • Lift the keyboard off the keyboard frame.
Заключение
6 участников успешно повторили данное руководство.
Alex Kwok
Участник с: 10/05/10
271 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 21-34, Regan Fall 2010 Участник Cal Poly, Team 21-34, Regan Fall 2010
CPSU-REGAN-F10S21G34
4 членов
Автор 11 руководств
2 Комментариев
Hey is keyboard replacement same or very similiar procedure with hp dv8000?
Arkadiusz Gąsior - Ответить
Brilliant. This is the best tutorial out there. Many thanks indeed!!!!
stevefranklin75 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 5
За всё время: 11,218
