Введение
In this guide, you will learn how to replace your RAM.
Инструменты
Запчасти
Remove the first memory module by spreading apart the two silver retaining tabs, using your thumb and index finger.
Pull and lift the green memory module upward at a 45-degree angle, and then pull the memory module out of the computer.
To replace the memory card, insert the card at a 45-degree angle, then push into slot.
Push down gently so the silver retaining tabs click back into place.
4 участников успешно повторили данное руководство.
