Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
The random access memory (RAM) stores temporary data for programs to use while they are running. Some programs use a lot of memory so it may be useful to replace RAM with ones with more memory on them.
Запчасти
Детали не указаны.
  1. Locate the battery on the bottom side of the laptop. Slide the release switch and the battery will pop out. Remove the battery
    • Locate the battery on the bottom side of the laptop.
    • Slide the release switch and the battery will pop out.
    • Remove the battery
  2. Using the Phillips #1, loosen the three 7mm captive screws that secure the memory module cover to the computer.
    • Using the Phillips #1, loosen the three 7mm captive screws that secure the memory module cover to the computer.
  3. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    Shop Kits
    Enough RAM
    For All The Tabs
    Shop Kits
  4. Remove cover and expose the memory module by lifting the cover up like its on a hinge. Remove cover and expose the memory module by lifting the cover up like its on a hinge. Remove cover and expose the memory module by lifting the cover up like its on a hinge.
    • Remove cover and expose the memory module by lifting the cover up like its on a hinge.
  5. Locate the release tabs on both sides of the RAM. Use non-conductive pointing tool or fingers to prevent static build up and damaging components. Pull the metal tabs away from the memory to release it.
    • Locate the release tabs on both sides of the RAM.
    • Use non-conductive pointing tool or fingers to prevent static build up and damaging components.
    • Pull the metal tabs away from the memory to release it.
    • Pull RAM away from clips to remove from device
    • Repeat for second RAM if necessary
Заключение
Еще один человек закончил это руководство.
Chad
Участник с: 13.01.2014
997 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 10-34, Maness Winter 2014 Участник Cal Poly, Team 10-34, Maness Winter 2014
CPSU-MANESS-W14S10G34
4 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 1,357
