Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
The random access memory (RAM) stores temporary data for programs to use while they are running. Some programs use a lot of memory so it may be useful to replace RAM with ones with more memory on them.
Выберете то, что вам нужно
Locate the battery on the bottom side of the laptop.
Slide the release switch and the battery will pop out.
Remove the battery
Using the Phillips #1, loosen the three 7mm captive screws that secure the memory module cover to the computer.
Remove cover and expose the memory module by lifting the cover up like its on a hinge.
Locate the release tabs on both sides of the RAM.
Pull the metal tabs away from the memory to release it.
Pull RAM away from clips to remove from device
Еще один человек закончил это руководство.
