Введение
If you are having complications with laptop having to boot and then shutting off, or blue screens of death, you may want to replace the motherboard.
Выберете то, что вам нужно
Use the PH 1 screwdriver to remove the four 3.5 mm screws securing the hard drive.
Remove a 3.5 mm screw that is securing DVD player with screwdriver PH1.
Unscrew four 3.5 mm screws from the inside of the battery compartment with PH 1 screwdriver.
Unscrew nine 5 mm screws with PH 1 screwdriver.
Unscrew four 4 mm screws with PH 1 screwdriver.
Flip side up and open laptop.
Pry open the keyboard using a plastic opening tool starting from the top.
Lift up plastic cover over keyboard connector cable.
Pull ribbon cable up away from keyboard to completely remove.
Flip laptop over.
Remove two 4mm screws securing antenna using PH 1 screwdriver.
Pull antenna to the right to remove.
Grab tab on left top corner and remove black wire.
Remove white input attachment.
10 участников успешно повторили данное руководство.
5 Комментариев
Great tutorial. Thanks!!!!
very Excellent tutorial …… Thank you
Excellent tutorial …. thank you
Nothing, thank you very much, it is a pleasure to help more people
Tomas -
