Введение
If you have broken your screen or your screen has black damage to it, you may want to replace your screen.
Выберете то, что вам нужно
Use the PH 1 screwdriver to remove the four 3.5 mm screws securing the hard drive.
Using tweezers, grab the top and bottom while rocking back and forth to pull rubber plug out.
Unscrew two 3mm screws using PH 1 screwdriver
Eight 6mm screws using PH 1 screwdriver.
Use PH 000 screwdriver to remove two 4mm screws.
Lift up plastic cover over keyboard connector cable.
Pull ribbon cable up away from keyboard to completely remove.
Flip laptop over.
Remove two 4mm screws securing antenna using PH 1 screwdriver.
Pull antenna to the right to remove.
Grab tab on left top corner and remove black wire.
Remove white input attachment.
Еще один человек закончил это руководство.
