HP Pavilion dv6-6180us Speaker Replacement
Выберете то, что вам нужно
  1. HP Pavilion dv6-6180us Speaker Replacement, Hard Drive: шаг 1, изображение 1 из 1
    • Turn off and unplug the device before starting.
    • Flip your device over so the bottom panel is facing up.
  2. HP Pavilion dv6-6180us Speaker Replacement: шаг 2, изображение 1 из 1
    • Slide the lock switch to the right.
    • The panel will pop open at the top corner.
  3. HP Pavilion dv6-6180us Speaker Replacement: шаг 3, изображение 1 из 1
    • Use the plastic opening tool to remove the back panel.
    • Some force may be required to remove the panel from the case. Use caution when prying to avoid breaking the panel or the plastic tabs securing it in place.
  4. HP Pavilion dv6-6180us Speaker Replacement: шаг 4, изображение 1 из 1
    • Use the PH 1 screwdriver to remove the four 3.5 mm screws securing the hard drive.
  5. HP Pavilion dv6-6180us Speaker Replacement: шаг 5, изображение 1 из 1
    • Lift the corner bracket to remove the hard drive.
  6. HP Pavilion dv6-6180us Speaker Replacement: шаг 6, изображение 1 из 1
    • Unplug the hard drive wire to detach the hard drive.
  7. HP Pavilion dv6-6180us Speaker Replacement, Speaker: шаг 7, изображение 1 из 1
    • Unscrew four 3.5 mm screws from the inside of the battery compartment with PH 1 screwdriver.
    • Unscrew nine 5 mm screws with PH 1 screwdriver.
    • Unscrew four 4 mm screws with PH 1 screwdriver.
  8. HP Pavilion dv6-6180us Speaker Replacement: шаг 8, изображение 1 из 1
    • Flip right-side up and open the laptop.
    • Pry open the keyboard using plastic opening tool starting from the top.
    • Lift up keyboard gently,as a silver ribbon is still attaching it to the laptop
  9. HP Pavilion dv6-6180us Speaker Replacement: шаг 9, изображение 1 из 1
    • Place keyboard upside down.
    • Lift up plastic cover over keyboard ribbon cable.
    • Pull ribbon cable up away from keyboard to completely remove.
  10. HP Pavilion dv6-6180us Speaker Replacement: шаг 10, изображение 1 из 1
    • Remove seven 4mm pannel screws with PH 1 screwdriver.
  11. HP Pavilion dv6-6180us Speaker Replacement: шаг 11, изображение 1 из 1
    • Put the computer on its side
    • Separate top panel from bottom frame.
  12. HP Pavilion dv6-6180us Speaker Replacement: шаг 12, изображение 1 из 1
    • Pop open palm rest panel.
  13. HP Pavilion dv6-6180us Speaker Replacement: шаг 13, изображение 1 из 1
    • Pull ribbon to detach from bottom panel.
  14. HP Pavilion dv6-6180us Speaker Replacement: шаг 14, изображение 1 из 2 HP Pavilion dv6-6180us Speaker Replacement: шаг 14, изображение 2 из 2
    • Lift up speaker.
  15. HP Pavilion dv6-6180us Speaker Replacement: шаг 15, изображение 1 из 1
    • Lift up white panel covering speaker ribbon cable.
  16. HP Pavilion dv6-6180us Speaker Replacement: шаг 16, изображение 1 из 1
    • Pull out the speaker ribbon.
  17. HP Pavilion dv6-6180us Speaker Replacement: шаг 17, изображение 1 из 2 HP Pavilion dv6-6180us Speaker Replacement: шаг 17, изображение 2 из 2
    • Unhook speaker cable from hooks.
  18. HP Pavilion dv6-6180us Speaker Replacement: шаг 18, изображение 1 из 1
    • Pull out silver wire to reveal black speaker wire.
  19. HP Pavilion dv6-6180us Speaker Replacement: шаг 19, изображение 1 из 1
    • Unplug the red, white, and black speaker wire connector.
Заключение
2 участников успешно повторили данное руководство.
michelle pulido
Участник с: 09/15/16
839 Репутация
Автор 4 руководств
Команда
CSU Fullerton, Team 1-2, Bruce Fall 2016 Участник CSU Fullerton, Team 1-2, Bruce Fall 2016
CSUF-BRUCE-F16S1G2
4 членов
Автор 4 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 4
За последние 30 дней: 16
За всё время: 2,483
