Введение
If your speakers are not functioning use this guide to instruct you on how to replace the beat audio speakers.
Выберете то, что вам нужно
Use the PH 1 screwdriver to remove the four 3.5 mm screws securing the hard drive.
Unscrew four 3.5 mm screws from the inside of the battery compartment with PH 1 screwdriver.
Unscrew nine 5 mm screws with PH 1 screwdriver.
Unscrew four 4 mm screws with PH 1 screwdriver.
Flip right-side up and open the laptop.
Pry open the keyboard using plastic opening tool starting from the top.
Lift up plastic cover over keyboard ribbon cable.
Pull ribbon cable up away from keyboard to completely remove.
2 участников успешно повторили данное руководство.
