Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Replace the optical drive assembly in your HP Pavilion dv6000.
Выберете то, что вам нужно
Remove the single 5.6 mm Phillips screw securing the optical drive to the lower case.
Insert the tip of an unrolled paper clip into the small hole located on the side of the optical drive.
Firmly pull the drive straight away from the laptop.
At this point you can remove the entire optical drive, or you can continue to disassemble the optical drive assembly.
Remove the three 3.2 mm screws securing the top plate of the optical drive.
Lift and remove the top plate up off the optical drive.
Pull the small ribbon cable straight away from its socket on the optical drive assembly board.
Use your fingernail to flip up the cable retaining flap on the ZIF socket for the larger ribbon cable.
Pull the larger ribbon cable straight out of its socket on the optical drive assembly board.
Lift and remove the optical drive assembly from the optical drive framework.
Optical drive assembly remains.
2 участников успешно повторили данное руководство.
