Введение
Replace the optical drive in your HP Pavilion dv6000.
Запчасти
No parts specified.
  1. Before proceeding, it is recommended to remove the battery to prevent any electrical damage to components.
    • Before proceeding, it is recommended to remove the battery to prevent any electrical damage to components.
    • Remove the single 5.6 mm Phillips screw securing the optical drive to the lower case.
  2. Android Fix Kits
    A new screen or battery is one kit away.
    Купить сейчас
    Android Fix Kits
    Купить сейчас
  3. Insert the tip of an unrolled paper clip into the small hole located on the side of the optical drive.
    • Insert the tip of an unrolled paper clip into the small hole located on the side of the optical drive.
    • The tray will partially pop out of the laptop.
    • Firmly pull the drive straight away from the laptop.
    • While pulling the drive out, be careful not to bend the sliding rails on both sides of the optical drive.
    • At this point you can remove the entire optical drive, or you can continue to disassemble the optical drive assembly.
Итог
6 участников успешно повторили данное руководство.
Walter Galan
609 061 Reputation
Автор 1 203 руководств
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 20
All Time: 7,736
