Введение
If you need more memory because your computer is running slowly, or you are having memory problems, the RAM is very easy to replace in the HP Pavilion dv6000.
  1. Remove the two screws from the memory shield and lift up.  The screws will remain into the shield Remove the two screws from the memory shield and lift up.  The screws will remain into the shield Remove the two screws from the memory shield and lift up.  The screws will remain into the shield
    • Remove the two screws from the memory shield and lift up. The screws will remain into the shield
  2. Using a plastic spudger depress the pins holding the RAM in. If you  have an anti-static work surface or wristband, you may suppress the pins with your thumbs. Static charge built up on surfaces contacting the RAM or other computer components can damage and destroy the components.  Always discharge yourself before handling these components! Pull the RAM straight out.
    • Using a plastic spudger depress the pins holding the RAM in. If you have an anti-static work surface or wristband, you may suppress the pins with your thumbs.
    • Static charge built up on surfaces contacting the RAM or other computer components can damage and destroy the components. Always discharge yourself before handling these components!
    • Pull the RAM straight out.
  3. Android Fix Kits
    A new screen or battery is one kit away.
    Купить сейчас
    Android Fix Kits
    Купить сейчас
  4. Under the first RAM stick is another. Remove it in the same way by pushing the silver tabs away and down from the RAM stick and remove the RAM once it pops up.
    • Under the first RAM stick is another. Remove it in the same way by pushing the silver tabs away and down from the RAM stick and remove the RAM once it pops up.
  5. You have removed your RAM!
    • You have removed your RAM!
    • If you want to expand your RAM you will have to use PC2-5300 SODIMM laptop memory modules, they are clocked at 667MHz
    • To reinstall your RAM, follow this guide in the reverse order
Итог
18 участников успешно повторили данное руководство.
Ben Hirsch
Участник с: 05.10.2010
3 688 Reputation
Автор 10 руководств
Cal Poly, Team 21-33, Regan Fall 2010 Member of Cal Poly, Team 21-33, Regan Fall 2010
CPSU-REGAN-F10S21G33
4 членов
Автор 10 руководств
2 Comments
if you have bios version f.25 or newer you can have up to 4gb of ram
Bryce Stidman - Ответить
2+2 or 4+4 ? which one?
Jes White -
Past 24 Hours: 6
Past 7 Days: 20
Past 30 Days: 59
All Time: 32,608
