Введение
In this guide, we will explain in a few short steps the process that will need to be taken in order to replace either of the RAM cards inserted in the laptop.
Инструменты
Запчасти
Детали не указаны.
Remove fifteen 7.0mm PH0 screws.
Remove five silver 4.0mm PH 0 screws inside the cavity for the battery.
Using your fingers or thin non metallic tweezers, pull the 2 silver levers on either side of the RAM card outward to until the ends pop up.
Slide the RAM cards out of their sockets.
3 участников успешно повторили данное руководство.
