Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Flip over the device so that the bottom is facing you.
Locate the battery on the bottom of your laptop.
Slide the tab all the way over to the left until battery pops out. Lift out and remove battery.
Use a Phillips #00 screwdriver to remove the two screws securing Hard Disk Drive (HDD) cover.
Use a Phillips #00 screwdriver to remove the 25 screws securing the bottom of the computer.
Flip over HP Pavilion dv6700 so that the top is facing you.
Open up HP Pavilion dv6700.
Use an iFixit opening tool to pry open the plastic bar above the keyboard.
Pull out and up on keyboard to remove it.
Slide the two black locks on the side of the keyboard cable connection port up to release the cable.
Grip the ribbon cable near the connection point and gently but firmly pull it out.
Pull up on the WiFi wires and out from under the metal tabs.
Disconnect the connector from the port.
Remove the wire from under the metal tabs.
Let wire hang loose after removing under the tabs.
Use a Phillips #00 screwdriver to remove the black screw located in the top right corner near the display.
Use a Phillips #00 screwdriver to remove the black screw securing the screen.
Lift the screen off and set it aside.
2 участников успешно повторили данное руководство.
