Введение
This is for if you need to get into the guts of the HP Pavilion dv6700. Be sure to have the anti-static strap on, as you will be coming into contact with circuitry and could permanently damage the pieces with static electricity.
Инструменты
Запчасти
Детали не указаны.
Slide tab all the way over to the left until battery pops out. Lift out and remove battery.
Remove two screws.
Use a needle-nose pliers to do the initial loosening, then switch to using a hex screwdriver (size 5) head to do the rest of the loosening.
Pull out and up on keyboard to remove it.
Slide the two black locks on the side of the keyboard cable connection port up to release the cable.
Grip the ribbon cable near the connection point and gently but firmly pull it out.
Detach the ribbon cables.
Pull from the area closest to the connection port gently but firmly.
Disconnect the connector from the port.
Remove the wire from under the metal tabs.
Let wire hang loose after removing under the tabs.
Remove the black screw from the top left corner.
Lift the screen off and set it aside.
Unscrew the black screw in the top right corner.
Pull up on the top piece and remove it.
Remove screw in top left corner.
Remove screws on motherboard cover.
Pull up on the cover to remove it.
Pull gently but firmly on the ribbon cables at the connection points to remove them
Remove ExpressCard component by sliding it out.
Remove Optical Drive by sliding it out.
Lift up motherboard.
Detach the motherboard connector at the front under the motherboard.
Lift up and out the motherboard.
Detach the connector under the motherboard.
Remove the motherboard.
7 участников успешно повторили данное руководство.
Комментариев: 2
Thank you for all your help . Very decent of you.
Spot on guide and detail.
Ian, Poynton< Cheshire
UK.
