HP Pavilion dv7-1285dx Keyboard Replacement
Выберете то, что вам нужно
  1. HP Pavilion dv7-1285dx Keyboard Replacement, Battery: шаг 1, изображение 1 из 1
    • Ensure the device is powered down and unplugged.
    • Turn the device upside down with the battery compartment facing you.
    • Slide the black slider to the right and lift the battery out of its compartment.
  2. HP Pavilion dv7-1285dx Keyboard Replacement, Keyboard: шаг 2, изображение 1 из 2 HP Pavilion dv7-1285dx Keyboard Replacement, Keyboard: шаг 2, изображение 2 из 2
    • Using a Phillips Screwdriver, remove the four Phillips M25x3.0 head screws.
  3. HP Pavilion dv7-1285dx Keyboard Replacement: шаг 3, изображение 1 из 2 HP Pavilion dv7-1285dx Keyboard Replacement: шаг 3, изображение 2 из 2
    • Using a plastic opening tool on both the left and right sides to remove the upper portion of the top plate.
    • Orient the device such that it’s partially opened (a little less than a 45 degree angle) and the hinge faces up.
  4. HP Pavilion dv7-1285dx Keyboard Replacement: шаг 4, изображение 1 из 2 HP Pavilion dv7-1285dx Keyboard Replacement: шаг 4, изображение 2 из 2
    • Orient the laptop so the screen is open and facing you.
    • Grasp the top plate near the hinge and pull up.
    • This should expose a white ribbon cable.
  5. HP Pavilion dv7-1285dx Keyboard Replacement: шаг 5, изображение 1 из 2 HP Pavilion dv7-1285dx Keyboard Replacement: шаг 5, изображение 2 из 2
    • Locate the dark grey slide on the sides of the ribbon cable plug.
    • Using the plastic opening tool, push both sides of the dark gray slide towards the screen of the computer.
    • Unplug the ribbon cable and set the top plate aside.
  6. HP Pavilion dv7-1285dx Keyboard Replacement: шаг 6, изображение 1 из 2 HP Pavilion dv7-1285dx Keyboard Replacement: шаг 6, изображение 2 из 2
    • Locate the four Phillips M2.0x2 head screws at the top of the keyboard and remove them.
    • Gently lift the keyboard up from the screen side and pull the keyboard towards the screen.
  7. HP Pavilion dv7-1285dx Keyboard Replacement: шаг 7, изображение 1 из 3 HP Pavilion dv7-1285dx Keyboard Replacement: шаг 7, изображение 2 из 3 HP Pavilion dv7-1285dx Keyboard Replacement: шаг 7, изображение 3 из 3
    • Locate the black ribbon cable attaching the keyboard to the computer.
    • Find the grey slides on the side of the ribbon cable plug.
    • Use the plastic opening tool to move the grey slides toward the screen.
    • Unplug the black ribbon cable.
    • Remove the keyboard.
Заключение
2 участников успешно повторили данное руководство.
Jesse Quisido
Участник с: 04/14/14
489 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 12-34, Maness Spring 2014 Участник Cal Poly, Team 12-34, Maness Spring 2014
CPSU-MANESS-S14S12G34
4 членов
Автор 7 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 13
За всё время: 3,792
