Введение
This guide demonstrates how to remove and insert a key into the laptop. This is helpful if a key is missing, needs to be removed for cleaning, or needs to replaced.
Выберете то, что вам нужно
Make sure the computer is unplugged and turned off.
Open the laptop so that the keyboard is fully exposed.
Place the plastic opening tool in the crevice near the key that needs to be removed.
Gently lever the tool downward until the key tilts upward.
At this point, move the tool around in order to completely pry the key off the keyboard. As the key is removed, small pops will be heard.
If the issue is a sticky key, make sure to clean the area once it is removed.
Use a cotton swab with alcohol to clean the underside of the key and the key slot.
