HP Pavilion dv7-3065dx Hard Drive Replacement
Выберете то, что вам нужно
  1. HP Pavilion dv7-3065dx Hard Drive Replacement, Battery: шаг 1, изображение 1 из 2 HP Pavilion dv7-3065dx Hard Drive Replacement, Battery: шаг 1, изображение 2 из 2
    • Turn off the device before removing the battery.
    • Place the laptop upside down on a flat surface so that the bottom is facing up.
    • The battery is the long rectangle above the latch.
  2. HP Pavilion dv7-3065dx Hard Drive Replacement: шаг 2, изображение 1 из 1
    • Slide the battery latch to the left to release the battery.
  3. HP Pavilion dv7-3065dx Hard Drive Replacement: шаг 3, изображение 1 из 2 HP Pavilion dv7-3065dx Hard Drive Replacement: шаг 3, изображение 2 из 2
    • Carefully pull out the battery while holding the latch to the open position with your finger.
  4. HP Pavilion dv7-3065dx Hard Drive Replacement, Hard Drive: шаг 4, изображение 1 из 1
    • Loosen the four screws that secure the hard drive panel with a Phillips head screwdriver.
    • Do not completely remove the screws from the panel.
  5. HP Pavilion dv7-3065dx Hard Drive Replacement: шаг 5, изображение 1 из 1
    • Lift the drive cover to expose the hard drive.
    • This device did not have a physical hard drive to work with.
    • Gently tug on the black tabs located on each end of the hard drive in order to loosen the hard drive from the motherboard.
    • Be careful when working with the hard drive cable.
    • Separate the hard drive from the cable by firmly gripping the hard drive and the black plug.
    • Remove the four Phillips screws that secure the hard drive to its carrier.
    • There are two screws on each side.
    • Lift and remove the hard drive from the metal surrounding its perimeter.
Заключение
2 участников успешно повторили данное руководство.
Gabi Marino
Участник с: 02/07/17
157 Репутация
1 руководство автора
Команда
Ohio State, Team 1-5, Wilder Spring 2017 Участник Ohio State, Team 1-5, Wilder Spring 2017
OSU-WILDER-S17S1G5
4 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 20
За всё время: 3,506
