HP Pavilion dv7-3065dx Keyboard Replacement
Выберете то, что вам нужно
  1. HP Pavilion dv7-3065dx Keyboard Replacement, Battery: шаг 1, изображение 1 из 2 HP Pavilion dv7-3065dx Keyboard Replacement, Battery: шаг 1, изображение 2 из 2
    • Turn off the device before removing the battery.
    • Place the laptop upside down on a flat surface so that the bottom is facing up.
    • The battery is the long rectangle above the latch.
  2. HP Pavilion dv7-3065dx Keyboard Replacement: шаг 2, изображение 1 из 1
    • Slide the battery latch to the left to release the battery.
  3. HP Pavilion dv7-3065dx Keyboard Replacement: шаг 3, изображение 1 из 2 HP Pavilion dv7-3065dx Keyboard Replacement: шаг 3, изображение 2 из 2
    • Carefully pull out the battery while holding the latch to the open position with your finger.
  4. HP Pavilion dv7-3065dx Keyboard Replacement, Hard Drive: шаг 4, изображение 1 из 1
    • Loosen the four screws that secure the hard drive panel with a Phillips head screwdriver.
    • Do not completely remove the screws from the panel.
  5. HP Pavilion dv7-3065dx Keyboard Replacement: шаг 5, изображение 1 из 1
    • Lift the drive cover to expose the hard drive.
    • This device did not have a physical hard drive to work with.
    • Gently tug on the black tabs located on each end of the hard drive in order to loosen the hard drive from the motherboard.
    • Be careful when working with the hard drive cable.
    • Separate the hard drive from the cable by firmly gripping the hard drive and the black plug.
    • Remove the four Phillips screws that secure the hard drive to its carrier.
    • There are two screws on each side.
    • Lift and remove the hard drive from the metal surrounding its perimeter.
  6. HP Pavilion dv7-3065dx Keyboard Replacement, Keyboard: шаг 10, изображение 1 из 1
    • Locate these seven screws that fasten the keyboard and switch cover to the computer.
    • Remove these screws
  7. HP Pavilion dv7-3065dx Keyboard Replacement: шаг 11, изображение 1 из 1
    • Flip over the computer to the upright position and locate the switch cover.
    • Carefully pry the switch cover up until it detaches from the computer.
    • The switch cover is held in with plastic clips. They may break if they are removed too forcefully.
  8. HP Pavilion dv7-3065dx Keyboard Replacement: шаг 12, изображение 1 из 1
    • Raise the switch cover to expose the speaker assembly.
    • Carefully detach the ribbon cables from the speaker assembly.
    • Locate and remove these four screws from the switch cover.
  9. HP Pavilion dv7-3065dx Keyboard Replacement: шаг 13, изображение 1 из 2 HP Pavilion dv7-3065dx Keyboard Replacement: шаг 13, изображение 2 из 2
    • Locate and remove the screws that hold the keyboard to the computer.
    • Lift the keyboard up to expose the keyboard connector.
    • The keyboard connector is the small cord located near the screen of the computer.
  10. HP Pavilion dv7-3065dx Keyboard Replacement: шаг 14, изображение 1 из 2 HP Pavilion dv7-3065dx Keyboard Replacement: шаг 14, изображение 2 из 2
    • Disconnect the keyboard connector by unhinging the blue plastic clips and gently pulling the cord.
    • The keyboard can now be removed from the computer.
Заключение
2 участников успешно повторили данное руководство.
Nicholas Moore
Участник с: 02/07/17
302 Репутация
Автор 2 руководств
Команда
Ohio State, Team 1-5, Wilder Spring 2017 Участник Ohio State, Team 1-5, Wilder Spring 2017
OSU-WILDER-S17S1G5
4 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 20
За всё время: 1,819
