Введение
Replacing any component in a laptop requires patience, strong organization skills, and a good work space. With enough patience and perseverance anyone can do it!
In order to successfully replace the dv7 cooling fan you need to work on a flat surface with good lighting and plenty of room to keep small parts organized so that the computer can be put back together without issue.
Make sure enough time is set aside to complete the process in one sitting. This project's estimated time frame is 4 to 6 hours.
WARNING: Before touching electronic computer components, such as the motherboard, CPU, or RAM, discharge all static electricity by touching a grounded metal object.
WARNING: Disassembling a laptop and replacing components by yourself often voids the warranty. Handle all computer parts with care, and be patient.
Выберете то, что вам нужно
The latch pictured on the bottom of the laptop holds the battery in place. Slide the latch to the left to remove the battery.
Slide the latch to the right to release the t-shaped plastic cover.
Lift the cover up and gently remove it.
Sketch a diagram of the bottom of the laptop. Make sure to mark all of the screw holes.
Carefully remove all twenty screws from the external laptop case.
Remove the eight Phillips PM2.5x5.0 screws from both hard drive compartments, and place them on the diagram.
Carefully place all screws in the correct spot on the diagram. Many screws are different sizes and lengths. It is extremely important that all screws go back into the same screw hole they came out of during re-assembly.
Disconnect the hard drive by gently pulling the plastic tab connector from the motherboard port.
Remove the empty hard drive bracket and hard drive. Set them aside until re-assembly.
Remove the screws from the hard drive compartments and place them in the matching places on the diagram.
Gently push the tabs away from the sides of the RAM chips to release them. (Push the tabs in the direction of the arrows.)
Remove both RAM chips by gently pulling them out at a 45 degree angle.
To begin removing the wireless card, disconnect the attached wires.
Remove the two PM 2.0x4.0 screws from the corners of the wireless card. Removing the screws will cause the wireless card to pop up.
Carefully remove the wireless card.
Place your fingernails in-between the crevice of the CD drive and the main body of the laptop. Carefully pull the drive out of the slot.
Turn the laptop right-side-up, and open the screen. Loosen the keyboard by carefully prying it up using your fingernails, carefully working along the edges.
Slowly lift the keyboard away from the case.
Lift the plastic tab that connects the keyboard ribbon cable to the motherboard.
Set the keyboard aside.
Carefully lift the four plastic tabs under the keyboard, and gently disconnect the ribbons under each one.
Use your fingers to release the top cover. Start at the top right corner. and work your way around the faceplate.
Lift the tab covering the SD card reader ribbon to unplug it.
Gently pull the SD card reader wires to disconnect them from the motherboard.
Unplug the speaker wire from the port in the lower left hand corner of the laptop.
Gently pull the plastic tab attached to the display wire to disconnect the display.
Disconnect the fan power supply cable.
Remove the power supply cord from the port on the right hand side of the motherboard (marked with red box).
Remove the five screws that hold the motherboard and fan in place.
Carefully remove the motherboard and fan.
Flip the motherboard over. Use a micro- screwdriver to remove the screws holding the fan assembly in place.
Remove screws from the heat sink assembly using a #1 Phillips screwdriver.
The old fan can be removed by sliding it out of the fan/heat sink assembly.
Insert the new fan into the fan slot in the fan/heat sink assembly. Put the assembly back together with the micro screws.
Use cotton swabs, paper towels, and alcohol to gently remove old thermal compound from the fan/heat sink assembly and motherboard.
Apply a small amount of new thermal compound to the center of the brass section of the heat sink. Both areas that need new thermal compound are marked with red boxes.
Re-attach the heat sink assembly to the motherboard.
Using light pressure, shift the fan/heat sink gently back and forth to spread the thermal compound. This makes a solid connection between the heat sink and motherboard.
Follow the steps in reverse order to reassemble.
Once you have reassembled the laptop, your repair is complete. If you need additional help, see the HP Pavilion dv7 Maintenance and Service Guide on HP's support website (link to guide: http://h10032.www1.hp.com/ctg/Manual/c03...).
43 участников успешно повторили данное руководство.
15 Комментариев
My HP Pavilion dv7 Cooling Fan failed and this procedure was exactly what I needed to install a new fan. The steps are right on. I would have done a lot of experimentation and possible damage had I not had this reference to follow. Thank you very much.
You used way too much thermal compound.
A pea sized drop will be just fine, my dude.
the link works just fine!by the way author i thank you for your work,its really help me!!
Extremely helpful,thank you
