Введение
A guide on how to replace the palm rest on a HP Pavilion dv7t-7000 laptop.
Выберете то, что вам нужно
Hold the release switch all of the way to the left and your other hand to pull the battery out.
Push the retraining springs away from the RAM at the same time to unlock the RAM.
Wedge a spudger in between the keyboard and the upper bezel (nearest the screen).
Pry upward to release the keyboard clips.
Use the flat end of a spudger to flip up the black tab on the ZIF connectors.
Pull the ribbon cables out of the ZIF connectors.
Remove the keyboard.
Flip the keyboard back over.
Remove the single Phillips #00 screw holding in the CD drive.
Pull out the CD drive.
Remove the seventeen Phillips #00 screws securing the back panel to the laptop.
