Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
How to replace the speaker on a HP Pavilion dv7t-7000 laptop.
Запчасти
Детали не указаны.
  1. Turn the computer off and disconnect if from all power sources.
    • Turn the computer off and disconnect if from all power sources.
  2. Slide the battery release switch to the left.
    • Slide the battery release switch to the left.
  3. Hold the release switch all of the way to the left and your other hand to pull the battery out.
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. Unscrew the single Phillips #00 screw.
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  5. Remove service hatch by sliding away from the computer and lifting up. Remove service hatch by sliding away from the computer and lifting up.
    • Remove service hatch by sliding away from the computer and lifting up.
  6. Remove the single Phillips #00 screw. Flip the laptop over.
    • Remove the single Phillips #00 screw.
    • Flip the laptop over.
  7. Wedge a spudger in between the keyboard and palm rest bezel. Pry upward to release the keyboard clips. The keyboard is plugged into the motherboard, so be careful not to pull out while lifting keyboard.
    • Wedge a spudger in between the keyboard and palm rest bezel.
    • Pry upward to release the keyboard clips.
    • The keyboard is plugged into the motherboard, so be careful not to pull out while lifting keyboard.
  8. Use the flat end of a spudger to flip up the black tab on the ZIF connectors.
    • Use the flat end of a spudger to flip up the black tab on the ZIF connectors.
    • Pull the ribbon cables out of the ZIF connectors.
    • Remove the keyboard.
  9. Use Phillips #00 to unscrew the screw and take off the front panel. Use Phillips #00 to unscrew the screw and take off the front panel. Use Phillips #00 to unscrew the screw and take off the front panel.
    • Use Phillips #00 to unscrew the screw and take off the front panel.
  10. The speaker is located at the back side of the front panel. Unscrew two screws located at the speaker.
    • The speaker is located at the back side of the front panel.
    • Unscrew two screws located at the speaker.
  11. Pull out the speakers to remove.
    • Pull out the speakers to remove.
Заключение
Nabin Bhatta
Участник с: 11.02.2018
258 Репутация
Автор 2 руководств
Команда
University of North Texas, Team S1-G1, Thompson Spring 2018 Участник University of North Texas, Team S1-G1, Thompson Spring 2018
UNT-THOMPSON-S18S1G1
6 членов
Автор 11 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 161
