Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Turn the laptop over to expose the bottom side.
Locate the battery removal switch next to the battery compartment
Slide the switch all the way to the left to release the battery. The battery should pop up.
Lift the battery out.
Locate the middle plastic cover on the bottom of the laptop.
Unscrew the two 5mm screws using a Phillips #1 screwdriver. The screws should remain in the plastic cover.
Lift and remove the plastic cover.
Locate the RAM card and the metal tabs on either side of it.
Press both tabs away from the RAM card to release it. The card should flip up towards you.
Carefully lift the RAM card out.
Еще один человек закончил это руководство.
