HP Pavilion dv9000 Wireless Card Replacement
Выберете то, что вам нужно
  1. HP Pavilion dv9000 Wireless Card Replacement, Battery: шаг 1, изображение 1 из 1
    • Turn the laptop over to expose the bottom side.
    • Locate the battery removal switch next to the battery compartment
    • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
  2. HP Pavilion dv9000 Wireless Card Replacement, Battery Removal: шаг 2, изображение 1 из 2 HP Pavilion dv9000 Wireless Card Replacement, Battery Removal: шаг 2, изображение 2 из 2
    • Slide the switch all the way to the left to release the battery. The battery should pop up.
    • Lift the battery out.
  3. HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: шаг 3, изображение 1 из 3 HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: шаг 3, изображение 2 из 3 HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: шаг 3, изображение 3 из 3
    • Locate the panel that lies in the front center of the laptops underside.
    • Using a Phillips #1 screwdriver, remove the two 5mm screws on the forward end of the cover.
    • Lift off the cover to expose the Wi-Fi card underneath.
  4. HP Pavilion dv9000 Wireless Card Replacement: шаг 4, изображение 1 из 3 HP Pavilion dv9000 Wireless Card Replacement: шаг 4, изображение 2 из 3 HP Pavilion dv9000 Wireless Card Replacement: шаг 4, изображение 3 из 3
    • Locate the Wi-Fi card inside of the computer.
    • With a Phillips #1 screwdriver, remove the two 11mm screws on either side of the wires attached to the top of the Wi-Fi card.
    • Lift the card from its resting location. Be careful, the card and attached wires are fragile.
  5. HP Pavilion dv9000 Wireless Card Replacement: шаг 5, изображение 1 из 2 HP Pavilion dv9000 Wireless Card Replacement: шаг 5, изображение 2 из 2
    • Carefully pop the wires off of the Wi-Fi card. They should easily come off with a light tug.
    • As you take each wire off, keep track of the numbered labels. These numbers correspond with contact points on the card.
Заключение
2 участников успешно повторили данное руководство.
Erik Hoffnagle
Участник с: 04/11/13
750 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 10-32, Maness Winter 2014 Участник Cal Poly, Team 10-32, Maness Winter 2014
CPSU-MANESS-W14S10G32
4 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 8
За всё время: 3,936
