Введение
The fan is one of the more tedious components of your device to remove. It has several prerequisite guides, but when you get to the fan, it is very easy to remove.
Выберете то, что вам нужно
Unscrew the two screws JIS #0 located on opposites sides of the panel.
Unscrew all nine 6.0mm JIS #0 screws located on the border of the back panel.
Remove 6 screws located under the spot where the smaller L-shaped panel was located.
In lower left hand corner, pull on black tab to unplug the disc drive.
In upper left hand corner, unplug the large black electrical tape covered laptop plug.
