Введение
Although it does not have many prerequisites, the screen is without a doubt the most difficult part of the laptop to remove. There are several hidden screws and wire that need to be carefully removed.
Выберете то, что вам нужно
Remove two triangular shaped screw covers in the bottom corners of the monitor near the hinges.
Unscrew the two 4.0 mm JIS #0 screws holding the hinge covers.
Еще один человек закончил это руководство.
