HP Pavilion g4-1117dx Trackpad Replacement
Выберете то, что вам нужно
  1. HP Pavilion g4-1117dx Trackpad Replacement, Battery: шаг 1, изображение 1 из 1
    • Slide pill shaped tab to the other side of the channel.
    • Remove battery while keeping the tab to the side.
  2. HP Pavilion g4-1117dx Trackpad Replacement, L-Shaped Back Panel: шаг 3, изображение 1 из 1
    • Unscrew the two screws JIS #0 located on opposites sides of the panel.
    • Screws are attached to the panel and will not fully come out.
  3. HP Pavilion g4-1117dx Trackpad Replacement: шаг 4, изображение 1 из 1
    • Carefully pry off the L-shaped panel.
  4. HP Pavilion g4-1117dx Trackpad Replacement, Hard Drive: шаг 5, изображение 1 из 1
    • Pull out and unplug the tab on the right hand side.
  5. HP Pavilion g4-1117dx Trackpad Replacement, Larger Back Panel: шаг 6, изображение 1 из 1
    • Unscrew all nine 6.0mm JIS #0 screws located on the border of the back panel.
  6. HP Pavilion g4-1117dx Trackpad Replacement: шаг 7, изображение 1 из 1
    • Remove 3 screws located where the battery previously was.
  7. HP Pavilion g4-1117dx Trackpad Replacement: шаг 8, изображение 1 из 2 HP Pavilion g4-1117dx Trackpad Replacement: шаг 8, изображение 2 из 2
    • Remove 6 screws located under the spot where the smaller L-shaped panel was located.
  8. HP Pavilion g4-1117dx Trackpad Replacement: шаг 9, изображение 1 из 1
    • Slowly pry off the keyboard from the back panel.
    • Between the back panel and the keyboard there are two ribbon wires.
    • Remove slowly to not break the back panel. If it does not come off easily, check to see if all screws are removed.
  9. HP Pavilion g4-1117dx Trackpad Replacement: шаг 10, изображение 1 из 1
    • Unplug wires connecting back panel to keyboard.
  10. HP Pavilion g4-1117dx Trackpad Replacement, Trackpad: шаг 11, изображение 1 из 1
    • Actual trackpad does not come out since it is a part of the whole keyboard.
    • Locate loosely attached blue strip at the bottom of the computer.
    • Locate the left ribbon strip attached to small black and white box.
    • Flip up the black tab while pulling out the ribbon.
Заключение
Еще один человек закончил это руководство.
Robert Hamilton
Участник с: 03/01/18
1 165 Репутация
Автор 10 руководств
Команда
UMass Dartmouth, Team S2-G7, Simcock Spring 2018 Участник UMass Dartmouth, Team S2-G7, Simcock Spring 2018
UMASSD-SIMCOCK-S18S2G7
4 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 9
За последние 30 дней: 13
За всё время: 492
