Введение
Unlike other laptops and computers, the trackpad is a part of the keyboard so it can't really be replaced without replacing the entire keyboard. A much simpler solution that we show in this guide requires the removal and replacement of a small ribbon-like connector.
Выберете то, что вам нужно
Unscrew the two screws JIS #0 located on opposites sides of the panel.
Unscrew all nine 6.0mm JIS #0 screws located on the border of the back panel.
Remove 6 screws located under the spot where the smaller L-shaped panel was located.
Locate loosely attached blue strip at the bottom of the computer.
Locate the left ribbon strip attached to small black and white box.
Flip up the black tab while pulling out the ribbon.
Еще один человек закончил это руководство.
