HP Pavilion g6 Base Replacement
Выберете то, что вам нужно
    • Simply slide the lever to the opposite position, and then the battery will rise upward. Grab it and pull it out.
  1. HP Pavilion g6 Base Replacement, Remove palmrest screws & bottom cover: шаг 2, изображение 1 из 1
    • Remove the five M2.5xL6.5 palmrest screws...
    • ...as well as the captive bottom cover screw. Slide the bottom cover away from you and pull it up.
  2. HP Pavilion g6 Base Replacement, Remove more screws & hard drive: шаг 3, изображение 1 из 1
    • Remove the four M2.5xL6.5 screws securing the keyboard, disc drive, and palmrest.
    • Pull upwards on the hard drive connector, and remove the hard drive.
    • Remove the two M2.5xL4 screws revealed by removing the hard drive.
    • Remove the single small screw holding the wireless card, and undo the antenna connections.
    • Use your fingernails to get between the palmrest and the keyboard, and pry the keyboard out.
    • Unlock the connector underneath the keyboard, and remove the cable from the connector.
  3. HP Pavilion g6 Base Replacement, Remove palmrest cables & screws: шаг 5, изображение 1 из 1
    • Undo the lock of the power button cable, and pull the cable out.
    • Repeat the process for the touchpad cable...
    • ...as well as the speaker cable.
    • Remove the three M2.5x4 screws securing the palmrest.
  4. HP Pavilion g6 Base Replacement, Undo cables: шаг 6, изображение 1 из 1
    • Undo the lock for the USB port connector, and pull the cable out. Also pull on the power jack connector right beside it.
    • Pull up on the optical drive connector.
    • At this point, the motherboard should simply lift upwards.
  5. HP Pavilion g6 Base Replacement, Remove LCD assembly, DC Jack & USB Board: шаг 7, изображение 1 из 1
    • Pull the clip for the USB board to the left, and pull up on the USB board.
    • Pull up on the DC jack.
    • Remove the two M2.5xL6.5 screws securing the right hinge to the base. Do the same for the left side.
  6. HP Pavilion g6 Base Replacement, Remove optical drive connector: шаг 8, изображение 1 из 1
    • Pull on the clip for the optical drive connector, and then pull the connector out.
Заключение
8 участников успешно повторили данное руководство.
Joseph Sctbunio
Участник с: 09/23/17
7 332 Репутация
Автор 42 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 49
За всё время: 9,726
