Введение
If the CD drive is damaged or needs to be removed to get to another component of the laptop, this is a guide to do so.
Выберете то, что вам нужно
Flip the computer so the bottom is facing up with the battery away from you.
Slide the battery switch to the left until the battery unlatches from the base of the laptop.
Loosen the two 5.7 mm screws on the bottom panel using a PH00 screwdriver.
Почти готово!
Заключение
