HP Pavilion g6-1b79dx Keyboard Replacement
Выберете то, что вам нужно
  1. HP Pavilion g6-1b79dx Keyboard Replacement, Battery: шаг 1, изображение 1 из 1
    • Flip the computer so the bottom is facing up with the battery away from you.
    • Turn off the computer and disconnect the charger.
  2. HP Pavilion g6-1b79dx Keyboard Replacement: шаг 2, изображение 1 из 2 HP Pavilion g6-1b79dx Keyboard Replacement: шаг 2, изображение 2 из 2
    • Slide the battery switch to the left until the battery unlatches from the base of the laptop.
  3. HP Pavilion g6-1b79dx Keyboard Replacement: шаг 3, изображение 1 из 2 HP Pavilion g6-1b79dx Keyboard Replacement: шаг 3, изображение 2 из 2
    • Lift the battery from its compartment away from the laptop.
  4. HP Pavilion g6-1b79dx Keyboard Replacement, Bottom Panel: шаг 4, изображение 1 из 1
    • Loosen the two 5.7 mm screws on the bottom panel using a PH00 screwdriver.
    • The screws do not come out of the panel due to small washers. Do not try to remove the screws completely.
  5. HP Pavilion g6-1b79dx Keyboard Replacement: шаг 5, изображение 1 из 1
    • Use the metal spudger all around the panel to pop it up from the base.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Using your finger is acceptable but not entirely recommended. Be gentle if you choose to use your hands.
  6. HP Pavilion g6-1b79dx Keyboard Replacement: шаг 6, изображение 1 из 3 HP Pavilion g6-1b79dx Keyboard Replacement: шаг 6, изображение 2 из 3 HP Pavilion g6-1b79dx Keyboard Replacement: шаг 6, изображение 3 из 3
    • With your hands, lift the panel completely off the base of the laptop.
  7. HP Pavilion g6-1b79dx Keyboard Replacement, Keyboard: шаг 7, изображение 1 из 1
    • Using a PH 00 screwdriver, remove the screw located next to the wireless card.
    • You can remove the wireless card for this process but it is not necessary.
    • This screw has a small keyboard icon next to it.
  8. HP Pavilion g6-1b79dx Keyboard Replacement: шаг 8, изображение 1 из 1
    • Flip the laptop over and open it.
    • The components beneath your computer may be loose and fall out when you flip the laptop. Be careful when turning it over.
  9. HP Pavilion g6-1b79dx Keyboard Replacement: шаг 9, изображение 1 из 3 HP Pavilion g6-1b79dx Keyboard Replacement: шаг 9, изображение 2 из 3 HP Pavilion g6-1b79dx Keyboard Replacement: шаг 9, изображение 3 из 3
    • Insert a plastic spudger or similar pry tool, beneath the keyboard, near the "insert" key, and pop the keyboard up from the laptop.
    • Starting at the opening you just created, run your fingers around the outside of the keyboard separating it from the rest of the computer.
    • Only lift the keyboard up a few inches because it is attached to the laptop by a ribbon cable.
  10. HP Pavilion g6-1b79dx Keyboard Replacement: шаг 10, изображение 1 из 3 HP Pavilion g6-1b79dx Keyboard Replacement: шаг 10, изображение 2 из 3 HP Pavilion g6-1b79dx Keyboard Replacement: шаг 10, изображение 3 из 3
    • Slightly angle the keyboard back so the ribbon connector underneath it is visible.
    • Remove the ribbon cable by using your fingers to pull up and away from the connector.
  11. HP Pavilion g6-1b79dx Keyboard Replacement: шаг 11, изображение 1 из 1
    • With the ribbon cable detached, you can now completely remove the keyboard.
Заключение
9 участников успешно повторили данное руководство.
patrickhall
Участник с: 09/23/15
730 Репутация
Автор 3 руководств
Команда
Baylor, Team 10-12, Williams Fall 2015 Участник Baylor, Team 10-12, Williams Fall 2015
BU-WILLIAMS-F15S10G12
3 членов
Автор 8 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 9
За последние 30 дней: 64
За всё время: 6,764
