Введение
This is a guide to remove the laptop's wireless card.
Выберете то, что вам нужно
Flip the computer so the bottom is facing up with the battery away from you.
Slide the battery switch to the left until the battery unlatches from the base of the laptop.
Loosen the two 5.7 mm screws on the bottom panel using a PH00 screwdriver.
2 участников успешно повторили данное руководство.
