Введение
The hard drive is an important part to a laptop. The hard drive's main function is store data for the laptop. Replace hard drive if it is faulty or a need to increase storage
Выберете то, что вам нужно
Use a Phillips #0 screw driver to loosen the screw. The screw will not detach from the cover.
Place your hand on the cover and slide the cover down.
Use your hand to lift the cover from the bottom right and slide the cover to the right to remove the cover.
Place one finger on the right side of the hard drive.
Push the hard drive to the left and lift the hard drive up to remove it from the device.
Disconnect the connecting part by pulling the part to the right.
Remove the hard drive from the device.
Еще один человек закончил это руководство.
