Введение
The optical drive allows the laptop to connect with CDs and disc to transfer information. It also allows laptop to play video or songs from the CD
Выберете то, что вам нужно
Use a Phillips #0 screw driver to loosen the screw. The screw will not detach from the cover.
Place your hand on the cover and slide the cover down.
Use your hand to lift the cover from the bottom right and slide the cover to the right to remove the cover.
Place one finger on the right side of the hard drive.
Push the hard drive to the left and lift the hard drive up to remove it from the device.
Disconnect the connecting part by pulling the part to the right.
Remove the hard drive from the device.
Put one finger into the release hole and push to the left until part of the optical drive comes out from the left of the laptop.
