Введение
This guide will give step by step instructions on how to remove the service door from an HP Pavilion g7-1365dx. Use this as a prerequisite guide for more involved guides.
Выберете то, что вам нужно
Flip the laptop so that it is upside down and opens away from you. This exposes the battery, it will be centered at the bottom of the laptop .
Push the switch above the battery towards the center of the laptop .
While pushing the switch, lift the battery by the side closest to the switch up and away from the laptop.
Using a Phillips size 0 screwdriver, unscrew the 2 Phillips screws.
Use the opening tool around the edges of the service door to loosen it and remove it.
