Введение
In this guide, you will learn how to replace the keyboard of your HP Pavilion g7-1368dx. this process takes roughly 25 minutes. The tools that you will need to preform this replacement are a Philips #1 Screwdriver, and the plastic iFixit opening tool.
Выберете то, что вам нужно
Turn the device over so that the lower case is facing up.
Slide the battery release latch. The battery will pop up.
Loosen the two Phillips #1 screws that connect the service panel to the device.
Slide the service panel down and pull it up to remove.
Flip the keyboard over and locate the black ribbon cable that attaches the keyboard to the device.
Using a plastic opening tool, flip up the white tab on the zero insertion force connector.
Disconnect the ribbon cable by sliding it out of the ZIF connector.
Remove the keyboard.
