Введение
The touchpad/track pad and power button are embedded into the upper case assembly for this device. There are a few reasons to replace the upper case assembly. The upper case may be broken, out of place, the touchpad/track pad no longer work, or the power button is broken. Whatever the reason, this guide will show you how to replace the upper case assembly.
Выберете то, что вам нужно
Place your finger on the battery lock slider, press toward the center of the laptop to unlock the battery.
Locate the hard drive cable connector pull tab.
Pinch the pull tab pulling upwards from the motherboard to disconnect the hard drive cable.
Use a spudger or other ESD-safe prying tool to lift one side of the hard drive up and out of the base enclosure.
Grab the end of the hard drive.
Pull the hard drive out of the base enclosure at an angle.
Using a Phillips #0 screwdriver, remove the optical drive anchor screw.
Orient the device so that you can remove the optical drive.
Using a spudger, slide out the optical drive enough so that you can grab it with your hand.
Using a Phillips #0 screwdriver, remove the Phillips M2.5×6.5 screw that secures the keyboard.
Insert the pointy end of a spudger into the two keyboard release holes and press down to disengage the keyboard from the device.
Use your fingers and grab the corner(s) of the keyboard and lift up towards the display panel.
Fold the keyboard over key side down onto the top cover so that it lays flat on the track pad.
Locate the keyboard cable connector.
Using a plastic opening tool, flip up the locking tab on the Zero Insertion Force (ZIF) connector.
Locate the power button cable near the top left corner of the upper case assembly.
Using a spudger, flip up the power button ribbon cable locking tab.
Using tweezers or a plastic opening tool, disconnect the speaker cable from the black connector located near the right side of the laptop.
Locate the track pad cable near the track pad.
Using tweezers, pull the trackpad ribbon cable out from the connector on the motherboard.
Remove the three Phillips M2.5 x 6.5 screws from the upper case assembly using a Phillips #0 screwdriver.
