Введение
Is your screen flickering, unreadably dim, shattered, or have lots of little black dots? Replacing your screen may solve these problems.
Выберете то, что вам нужно
The battery is held in by a latch in the front and tabs in the back.
Slide the lock switch left, towards the center of the computer.
Lift up the battery, rotating it up and away from you, then pull it out.
Unscrew one Phillips #1 screw from the back panel.
Use a Phillips #1 screw driver to unscrew the black 4 mm Phillips #1 screw on the wireless card.
Use a plastic opening tool to lift the wireless card out of its slot.
Pull the black and white wires up and off of the wireless card.
Remove the wireless card.
Unscrew the 7 mm Phillips #1 screw next to the keyboard icon.
Carefully pry up one of the top corners of the keyboard with a prying tool. Slide the tool along the top of the keyboard to release it from the housing. Pull the top of the keyboard towards you an inch or two.
Pull the keyboard up and away from you, as it is held in by clips in the front. It is not yet disconnected.
Using a prying tool, flip the black clip up and to the right. Pull the silver cable out and to the left, the keyboard is now detached from the laptop.
Use a plastic opening tool to lift the white clip up, towards the screen.
Pull the white cable with blue head, away from the clip.
With a plastic opening tool, pry open a side or corner of the top panel. Slide the tool around the rest of the panel to release it from the clips.
Rotate the top panel away from you, keeping the back near the hinge of the laptop to avoid damaging the speaker cable.
Using a plastic opening tool, disconnect the black speaker connector from the top right of the motherboard.
Set aside the top panel until your are ready to reassemble your laptop.
In the top left hand corner, disconnect the monitor cable from the motherboard by pulling up on the black tab.
Unscrew the four black 7 mm Phillips #1 screws that attach the hinges to the case.
Remove the screen assembly from the laptop.
Using tweezers, remove the two screw covers at the bottom of the screen.
Unscrew the two 6 mm Phillips #1 screws from the bottom of the screen.
Firmly pry the front screen cover off. Slide the prying tool around the front screen.
Gently remove the screen from its housing. Turn the screen over (parallel to you) and disconnect the webcam cable.
Separate the webcam cable from the screen.
Remove the four 4 mm Phillips #1 screws from the sides of the screen.
Remove the two hinge assemblies.
20 участников успешно повторили данное руководство.
2 Комментариев
or you could just pop of the plastic bezel and unscrew the LCD and then unplug the screen from the back and be done with it. You made way more work for yourself then what is needed.
Thank you for this guide! I was working on a screen replacement for an HP G7-1260us, but it was built so similarly to the one in your guide that I was able to follow the guide and successfully replace the screen.
There is no realistic risk of electric shock on a laptop. However, is it still advisable to disconnect power plug and battery before opening as there is a real risk of accidental damage by short-circuit.
antoniotavares - Ответить
