HP Pavilion g7-2275dx Wireless Card Replacement
Выберете то, что вам нужно
  1. HP Pavilion g7-2275dx Wireless Card Replacement, Battery: шаг 1, изображение 1 из 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
  2. HP Pavilion g7-2275dx Wireless Card Replacement: шаг 2, изображение 1 из 1
    • The battery is held in by a latch in the front and tabs in the back.
    • Slide the lock switch left, towards the center of the computer.
    • Lift up the battery, rotating it up and away from you, then pull it out.
    • To put the battery back in, line it up with the battery bay and the holes for the tabs. Then let the battery rotate towards you and press down until the latch engages and you hear a click.
  3. HP Pavilion g7-2275dx Wireless Card Replacement, Disassembling HP Pavilion g7-2275dx Back Panel: шаг 3, изображение 1 из 1
    • Unscrew one Phillips #1 screw from the back panel.
    • The screw is on a spring and attached to the panel. It will pop up, but will not separate from the back panel.
  4. HP Pavilion g7-2275dx Wireless Card Replacement: шаг 4, изображение 1 из 2 HP Pavilion g7-2275dx Wireless Card Replacement: шаг 4, изображение 2 из 2
    • Slide the back panel down and pull it up.
  5. HP Pavilion g7-2275dx Wireless Card Replacement, Wireless Card: шаг 5, изображение 1 из 1
    • Use a Phillips #1 screw driver to unscrew the black 4 mm Phillips #1 screw on the wireless card.
  6. HP Pavilion g7-2275dx Wireless Card Replacement: шаг 6, изображение 1 из 2 HP Pavilion g7-2275dx Wireless Card Replacement: шаг 6, изображение 2 из 2
    • Use a plastic opening tool to lift the wireless card out of its slot.
  7. HP Pavilion g7-2275dx Wireless Card Replacement: шаг 7, изображение 1 из 2 HP Pavilion g7-2275dx Wireless Card Replacement: шаг 7, изображение 2 из 2
    • Pull the black and white wires up and off of the wireless card.
    • Remove the wireless card.
Заключение
2 участников успешно повторили данное руководство.
John Sutton
Участник с: 04/24/14
1 566 Репутация
Автор 8 руководств
Команда
Cal Poly, Team 11-51, Amido Spring 2014 Участник Cal Poly, Team 11-51, Amido Spring 2014
CPSU-AMIDO-S14S11G51
4 членов
Автор 21 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 2,180
