Введение
If you need to replace the hard drive in your HP Pavilion x360 11-p110nr laptop, this guide will help you accomplish that. you may want to replace your hard drive if it starts to fail or you want to put in one with more storage.
Выберете то, что вам нужно
Turn the laptop over to access the backside of the computer.
Identify and confirm that the laptop is an HP Pavilion x360 11-p110nr.
Remove the nine screws from the back panel using a Phillips #0 screwdriver.
Remove the four screws holding in the hard drive compartment using a Phillips #0 screwdriver.
Pull the hard drive up and out to remove it from the compartment.
Еще один человек закончил это руководство.
