Введение
This guide shows you how to replace the charging port in your HP Pavilion x360 11-p110nr laptop. This repair may be necessary whenever the laptop is not able to charge, hold a charge, or power on.
Before committing to replacing the charging port, it is worth checking that the charger being used works. This can be accomplished by trying a different charger on the laptop, or trying the charger on a different laptop.
Using only a screwdriver and the replacement part, the entire process is fairly quick and easy, and with a bit of care it can be completed safely at home.
Caution: Anytime you are working with batteries or power, be sure to take care around the electricity and always unplug the battery before you attempt to replace the port.
Выберете то, что вам нужно
Use a Phillips #0 screwdriver to remove all 6.7 mm screws from the bottom cover.
Carefully take the bottom cover off.
Before fully removing the top cover, locate the cable that connects the audio controls.
Lift the small black flap holding the cable to the motherboard, and remove the cable.
The bottom plate can now be safely removed.
Using a Phillips #0 screwdriver, unscrew the 5.6mm screw on top connecting the shielding to the board.
Using a Phillips #0 screwdriver, unscrew the 3.2mm screw on the bottom connecting the shielding to the board.
Lift the hinge.
Remove the long shielding that was under the hinge.
Remove and replace the charging port.
