Введение
If your computer has a jammed key on the keyboard, within this guide you will find quick and easy directions on how to resolve the issue.
Выберете то, что вам нужно
Use a screwdriver or other flat instrument to get under the key, and pull up slightly on one of the edges.
Use the flat screw to put the key back into place.
Gently press the key down. It should snap back into place
Почти готово!
Финишная черта
