Введение
If the battery in your HP Pavilion x360 11m-ad013dx is in need of replacement or has stopped functioning properly, use this guide to replace the battery. Some key indicators of a malfunctioning battery include not turning on, only functioning when connected to power, or rapid depletion of the battery. For more information about a malfunctioning or nonfunctioning battery, see our troubleshooting page HP Pavilion x360 11m-ad013dx Troubleshooting. Be extremely cautious when handling damaged batteries. Signs of damage can include swelling or corroded connections. Swollen batteries can catch fire or even explode. See iFixit’s swollen battery page: What to do with a swollen battery for more information.
Выберете то, что вам нужно
Using a plastic spudger, remove the grey silicon strip closest to the back-side.
Open the HP Pavilion so that the screen is showing. Then tilt it down so that the screen is on its back, facing up.
Using a spudger, pry off the black keyboard panel.
Using your fingernail, disconnect the zero insertion force (ZIF) keyboard connector cable by flipping up the small locking flap.
Using your fingernail, disconnect the zero insertion force (ZIF) connector for the touch pad cable by flipping up the small locking flap.
Using a spudger for assistance, lift up the right edge of the battery.
Remove the battery.
Еще один человек закончил это руководство.
